Reification by Parametricity
A Coq formalisation of SQL’s execution engines
A Formally Verified Solver for Homogeneous Linear Diophantine Equations
Software Verification with ITPs Should Use Binary Code Extraction to Reduce the TCB (short paper)
A Formalization of the LLL Basis Reduction Algorithm
Verified Analysis of Random Trees
Proof Pearl: Constructive Extraction of Cycle Finding Algorithms
Fast machine words in Isabelle/HOL
Verified Tail Bounds for Randomized Programs
Program Verification in the Presence of Cached Address Translation
Towards Formal Foundations for Game Theory
A Coq Tactic for Equality Learning in Linear Arithmetic
Backwards and Forwards with Separation Logic
Verification of PCP-Related Computational Reductions in Coq
Relational parametricity and quotient preservation for modular (co)datatypes
Asynchronous Processes in Agda: From Paper to Formalised Proof
The Coinductive Formulation of Common Knowledge
Boosting the Reuse of Formal Specifications
Formalization of a Polymorphic Subtyping Algorithm
Physical addressing on real hardware in Isabelle/HOL
Towards Certified Meta-Programming with Typed Template-Coq
Verifying the LTL to Büchi Automata Translation via Very Weak Alternating Automata
ProofWatch: Watchlist Guidance for Large Theories in E
Formalizing Ring Theory in PVS (short paper)
Software tool support for modular reasoning in modal logics of actions
Verified Memoization and Dynamic Programming
Formalizing Implicative Algebras in Coq
Towards Verified Handwritten Calculational Proofs (short paper)
A Formal Proof of the Minor-Exclusion Property for Treewidth-Two Graphs
MDP + TA = PTA: Probabilistic Timed Automata, Formalized (Short Paper)
A Formal Equational Theory for Call-By-Push-Value
Verified Timing Transformations in Synchronous Circuits with LambdaPi-Ware
CalcCheck: A Proof Checker for Teaching the “Logical Approach to Discrete Math”
Efficient Mendler-Style Lambda-Encodings in Cedille
Understanding Parameters of Deductive Verification: An Empirical Investigation of KeY
Tactics and certificates in Meta Dedukti
HOL Light QE
